Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Help with TPS for FC Throttle body 2000 SE DOHC auto-trans
Old 12-12-2012, 03:12 AM   #6
Z3T3C
Fan#: 107116
What I Drive: 2000 SE Zetec with ATX
Points 134, Level 2
Points: 134, Level: 2 Points: 134, Level: 2 Points: 134, Level: 2
Level Up 68% Completed
FF Reputation: 1 Z3T3C Good Standing Member
Yeah, cutting out the old and splicing in the new connector with solder and heat shrink tubing (if you have it) is the way to go. The male end of the newer style tps are different, so once you upgrade you won't ever need the old connector. Still never got an answer on what TPS comes in the new throttle bodies, though. I solved my problem for the moment because I ended pulling a throttle body with old tps from a totaled '01 ZX3 at a junkyard for $60. The transmission is shifting nicely. However, the car is stalling/choking itself out. I'm wondering if its IAC or a plugged cat at this point. The exhaust smelled a bit like eggs during the test drive after the tps/throttle body swap.
Z3T3C is offline
