Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - LED experts chime in
Old 12-11-2012, 05:04 PM   #10
mr1mrwun
Fan#: 94331
What I Drive: '02 Gold SE
FF Reputation: 1 mr1mrwun Good Standing Member
Originally Posted by S0C0nFused View Post
OK. I have tried to find the more advanced kits for you. They apparently no longer exist. The closest one I could find is here
http://www.mtmscientific.com/timer.html
You would need to reengineer the output (relay not suitable),timing cycles etc. I was trying to find the dual timer brds but no luck. I wanted to stay with a 555 as they can drive a power trans directly.
Thanks for that.
Pardon my ignorance, like I said I'm still learning about LEDs and small circuits, but is that timer a standalone or would I just need integrate it into the car's flasher circuit past the GEM? Or is it something I can/should put on the bread board for each separate array?
Both you and the description says it's a kit. So some searching on DIY electronics forums are in order. Still have a lot of research and learning to do!
Btw, whats a brd?
mr1mrwun is offline
