Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - one touch up/down stopped working on my Ti
Old 12-11-2012, 12:10 PM   #3
suss6052
suss6052's Avatar
Fan#: 95752
Points 12,234, Level 72
Level Up 46% Completed
Buy-Sell-Trade Rating: (3)
Originally Posted by red-i View Post
last week, we had some cold weather and my windows were frozen shut. i waited awhile and once they heated up i noticed that both my front windows won't do the auto up/down anymore. it's the same whether i use the drivers controls or the front passenger control. both rears work fine.
strange, happened to anyone else?
If you kept trying to put them down while they were frozen shut you may have de-programmed the bounce back feature which also controls the functional limits of the window's travel that allows the one-touch power up/down to function. See your owner's guide or the following proceedure:
Resetting the Bounce-Back Feature
WARNING: The bounce-back function remains deactivated until
you have reset the memory.
You must reset the bounce-back memory separately for each window
after the battery has been disconnected.
1. Lift and hold the switch until the window is fully closed.
2. Release the switch.
3. Lift the switch again for one more second.
4. Press and hold the switch until the window is fully open.
5. Release the switch
6. Lift and hold the switch until the window is fully closed.
7. Open the window and then try to close it automatically.
8. Reset and repeat the procedure if the window does not close
automatically.
suss6052 is online now
