Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Front of car vibrates when clutch disengaged
Old 12-11-2012, 10:27 AM   #4
StephenElsbree1986
StephenElsbree1986's Avatar
Fan#: 104271
What I Drive: CD Silver 2003 SVT
Points 1,281, Level 19
Points: 1,281, Level: 19 Points: 1,281, Level: 19 Points: 1,281, Level: 19
Level Up 81% Completed
Level up: 81% Level up: 81% Level up: 81%
FF Reputation: 1 StephenElsbree1986 Good Standing Member
Its in the clutch bro. Engine mounts wont cause viberation when the clutch is engaged or disengaged, So its the ToB unit or possibly the Clutch Fork, if it rattles horribly
Originally Posted by tukaniSVT View Post
Hmm. I would start with the Motor mounts. Check to see if the rubber on the mounts are still good.
Then start checking for the vacuum leak. But on the clutch ... hmm.
Is the vibration only when the car is moving? And does it become even worst when you accelerate?
If it's when you accelerate, could be a few things. New to balance your tires, need an alignment, bad bearing (as you stated) or bad tie-rods.
Ray
StephenElsbree1986 is offline
