Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Fun with PlastiDip!
Old 12-11-2012, 10:00 AM   #2580
Kipp
FocusFest Event Team
Kipp's Avatar
Fan#: 31300
Points 4,856, Level 44
Level Up 53% Completed
you can, but it was to be done a different way. normally when you spray this you would do several light coats with some set time in between. however if you want to do lines where you would need to mask off then you'll want to do a quick spray method. lay your tape and you'll spray several layers a little faster with little time between coats. then you have to pull the tape before it dries so it cuts clean through the dip and leaves a sharp edge. if you let it dry then it will rip the dip when you pull the tape unless you want to cut that line after it dries and before pulling tape. a little more tricky method, but has great results if done right.
here's one of their vids that shows how to do it.
http://www.youtube.com/watch?v=2kBWaSDmj0g&feature=plcp
2010 Volvo C70
2011 Harley FLHTK
Midwest Crew #22
Kipp is offline
