Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Front of car vibrates when clutch disengaged
Old 12-11-2012, 06:46 AM   #3
tukaniSVT
FF PHOTOG ENTHUSIAST
tukaniSVT's Avatar
Fan#: 5521
What I Drive: 2003 SVT Focus 2009 BMW 335i
Points 39,119, Level 100
Points: 39,119, Level: 100 Points: 39,119, Level: 100 Points: 39,119, Level: 100
FF Reputation: 35 tukaniSVT Great Standing Member
Hmm. I would start with the Motor mounts. Check to see if the rubber on the mounts are still good.
Then start checking for the vacuum leak. But on the clutch ... hmm.
Is the vibration only when the car is moving? And does it become even worst when you accelerate?
If it's when you accelerate, could be a few things. New to balance your tires, need an alignment, bad bearing (as you stated) or bad tie-rods.
Ray
Hatch Nation Member: #147
R.I.P - FELLOW FF MEMBER, IZZY, BLK2k3GTS, will always be remembered. We will compete on a different course again one day.
tukaniSVT is offline
