Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Custom enclosure?
Old 12-10-2012, 08:06 PM   #5
dpando1
Fan#: 92144
What I Drive: 2012, Grey, Focus SE Sport Package
Points 225, Level 4
Points: 225, Level: 4 Points: 225, Level: 4 Points: 225, Level: 4
Level Up 50% Completed
FF Reputation: 2 dpando1 Good Standing Member
The best and most rewarding enclosure you can have in your hatch would be to build a fiberglass enclosure in either(or both) wells on the corners of your trunk. It literally is the most efficient use of space and acoustically it rocks....
You could carpet it or if you are really inclined you could smooth out the finish enough to paint it. This would be the perfect "custom" sub enclosure. Since it would be a sealed enclosure even less space is needed, the only downside is if you wanted a ported enclosure imo that would be impossible with this kind of set-up.
and heck you can mount the amp to the top of the trunk so as to not get in the way for your bike
dpando1 is offline
