Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Squeak after replacing Passenger Mount
Old 12-10-2012, 03:03 PM   #1
C00P88
Fan#: 45208
What I Drive: 2003 Pitch Black ZX3
Points 489, Level 9
Points: 489, Level: 9 Points: 489, Level: 9 Points: 489, Level: 9
Level Up 78% Completed
FF Reputation: 1 C00P88 Good Standing Member
Question Squeak after replacing Passenger Mount
I've replaced the passenger engine mount on my 03' zx3. I now get a squeaking noise from the engine bay while accelerating, usually going uphill. It's worse if I'm going over bumps, accelerating uphill. No noise if I'm cruising at a steady speed or rolling with the clutch engaged.
I've triple-checked the mount bolts and nuts, nothing is loose. I've tried changing the position of the engine, bolting it down with it pushed forward, all the way back, in the center position but the squeak continues.
I noticed today that the squeak appears AFTER the engine warms up.
I used thread locker blue on the nuts and bolts of the engine mount.
I've also replaced the lower mount - I started with a poly mount but didn't like the vibration so I'm back to rubber.
I'm wondering if this is really the mount, or something else was loosened by moving the engine around? I don't see anything obviously loose. If it's the mount then I guess my solution will be to turn the radio up. I can't get the bolts any tighter. Any suggestions?
C00P88 is offline
