Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - How do I remove the 2 triangular grille panels.
Old 12-10-2012, 02:03 PM   #7
2012sel
2012sel's Avatar
Fan#: 84814
What I Drive: 2012 Red Candy SEL 5 door
FF Reputation: 12 2012sel Great Standing Member
Originally Posted by pmullins View Post
HELP!! I have a 2012 Focus Titanium and bought LED running lights. The lights are built into the 2 "sail" panels on the front either side of the grille. I cannot figure out how to remove the panels. Took of the splash panel underneath but still can't see how they pop out.
1) First get some electrical tape to protect the paint. (see photo)
2) Get at least 5 butter knifes (the duller and thinner the better)
3) Stick the butter knifes between the bumper cover and grill piece where the clip tab locations are. Use at least 5 knifes to loosen the outermost 3 tabs and the 2 bottom tabs (indicated in green below). Verify you're knife is in the right spot to "unclip" each tab by looking under the car where the knifes will stick through. The knife needs to be carefully centered and go between the grill piece tab and the bumper cover tab to separate them. The bottom two tabs are easiest to see so get a feel for what I mean using those. Once you have those 5 knifes in, push the grill piece out on that side, remove the knifes and then seperate the remaining 3 tabs that are closest to the center (indicated in red below).
Current
2012 SEL 5 door w/Premium Package - April 2011 | 1957 Chevrolet 3200 - 2005
Past Rides
2000 F150 Sport 2000-2011 | 1988 Ranger XLT 4wd 1988 - 2000 | 1966 Mustang 1983 - 2008 | 1963 Ford Econoline Van 1979 - 1983
2012sel is offline
