Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - US to UK light conversions
Old 12-10-2012, 12:18 AM   #8
sailor
Old Phart
sailor's Avatar
Fan#: 57268
Points 31,343, Level 100
Points: 31,343, Level: 100 Points: 31,343, Level: 100 Points: 31,343, Level: 100
Forum Activity 100%
FF Reputation: 133 sailor Excellent Standing Member sailor Excellent Standing Member
Well, for "quick" wiring since you have a wire run already - if you probe around that relay box 'til you find what wire goes "hot" when the fogs turn on, just tap into that & you're done!
The rear light isn't high power draw, so this should be adequate. It's not like adding high power fogs in the front, when you'd use that feed to run a relay & direct power from the battery to power them....
More like when you're installing a stereo & you just need to find a switched power source & an unswitched one - any wire that supplies what you need is adequate 'cause the extra draw is low.....
luck!
sailor is online now
