Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - P0041 and P0123
Thread: P0041 and P0123
Old 12-09-2012, 10:11 AM   #5
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Points 2,406, Level 29
Points: 2,406, Level: 29 Points: 2,406, Level: 29 Points: 2,406, Level: 29
Level Up 71% Completed
Forum Activity 3%
Buy-Sell-Trade Rating: (3)
Your P0041 code is non-sensical because the 4 cylinder Focus only has a single bank of cylinders (V6s and V8s have two). It may be indicative of a wiring harness short. The only way to tell is to do a visual inspection of the downstream O2 sensor connectors and wires.
If the speedo sometimes quits as well it would be suggesting you have an electrical short somewhere.
If the DTC codes reappear, the problem is persistent. Your method of clearing the codes is correct, although using a proper OBDII code scanning device would be better.
BC_ZX3 is offline
