Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Installed the Steeda FSB and the Mazda 3 RMM today
Old 12-09-2012, 06:08 AM   #1
greg hazlett
Fan#: 93486
What I Drive: 2012 Black Ford Focus SE Hatchback
FF Reputation: 3 greg hazlett Good Standing Member
Buy-Sell-Trade Rating: (3)
Picked up the Steeda FSB to compliment the Steeda RSB I bought and did the install; I used the directions from Ford and if you are going to to do this install yourseld you need to have an air compressor and sockets up to 21mm; this was not an easy process and involves dropping the K member pretty low after you have everything unbolted as that is how the sway bar is removed, from the rear of the K member.
I messed up my passenger side tie rod end during the removal so I have to get a new one, luckily they are under $20 from Rockauto and then need to have it aligned.
The RMM was easy to do since I was doing the FSB at the same time and the initial impression is it help. The car seems quieter, idles better and is an overall solid piece. For under $50 so far it seems like a good investment.
Can't comment on the FSB being a worthwhile upgrade as I am not going crazy with the car with the damaged tie rod end; it was $159 shipped from Steeda so while the price isn't bad due to the involvement of the install I can't recommend it.
greg hazlett is offline
