Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Water in the tank, can't get it running again.
Old 12-09-2012, 01:28 AM   #2
mikebontoft
Aurelius Pardus
mikebontoft's Avatar
Fan#: 58647
What I Drive: 5.9L Grand Cherokee ZJ
Points 24,482, Level 95
Points: 24,482, Level: 95 Points: 24,482, Level: 95 Points: 24,482, Level: 95
Level Up 14% Completed
Level up: 14% Level up: 14% Level up: 14%
FF Reputation: 76 mikebontoft Excellent Standing Member
Buy-Sell-Trade Rating: (3)
have you checked the fuel cutoff switch just below the glove box on the kick panel? make sure its pushed in.
please check with starting fluid first if the cutoff is fine. if it runs then its still a fuel problem since you have verified spark. if it doesn't run, check the compression.
do not replace the pcm until your diagnosis leads you there
edit: verify that fuel is flowing through the injectors and that havent been seized. im not sure what water will do, if it could plug the screen or seize them.
SR #127 | '02 Focus SE "Foci" (5.0 RWD - parted) | '75 BMW 2002 "Carby" (racecar) | '98 Jeep Grand Cherokee 5.9L (lifted and fast) | '99 BMW 328is (daily).
Moderating
and
mikebontoft is offline
