Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Oil leak..back at the dealer.
Old 12-08-2012, 08:42 PM   #1
Vrod21
Vrod21's Avatar
Fan#: 86456
What I Drive: 2012 Tuxedo black metallic SE
FF Reputation: 3 Vrod21 Good Standing Member
Well, just had the radiator replaced 2 days ago as it was leaking coolant.
Noticed a drop of oil in the garage this afternoon. Looked underneath and found oil on the rear motor mount and all around that area.
Traced the leak back to the top of the engine (should have looked there first). There was oil all over the top of the the canal were all the plugs are. I was so frustrated I forgot to take a pic and went directly back to the dealer.
Dealer tried to tell me someone spilled oil on top the engine at the last oil change. I told them they did the 30k service about 400 miles prior and changed the radiator 2 days ago.
Seemed the the dealer was trying pass is off as a non issue. Oye. They did keep it and said they would check it out on Monday.
Issues to date:
-Coolant leak from a piece on the driver side of the engine.
-Driver side suspension clunk
-Valve cover gasket oil leak.
-Radiator coolant leak
-Another oil leak, unknown cause.
What next!
Vrod21 is offline
