Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2001 zx3 wont start
Old 12-08-2012, 02:32 PM   #9
Fan#: 107041
What I Drive: 2001 white ZX3
FF Reputation: 1 H8VTEC Good Standing Member
Originally Posted by iminhell View Post
Only 7 would sound fuel pump, not the FRPS. The sensor read 7 and you manually got 7, so it's working.
Pull the line before the Fuel Filter and see if that makes a difference. Hell, just replace the Fuel Filter being you're right there.
If there's no change you're going to be replacing the pump. How you want to go about that is up to you; cut an access hole or drop the tank.
Just make sure the pump you buy has the spring top (update pump).
I replaced the pump with a new one from a local parts store. I cut an access panel, way easier than removing the tank. What do you mean by spring top? Should i get it from the dealer?
H8VTEC is offline
