Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2 Noises
Thread: 2 Noises
Old 12-08-2012, 12:52 PM   #3
Neptune15
Neptune15's Avatar
Fan#: 91691
What I Drive: '07 ZX3
Points 1,032, Level 17
Points: 1,032, Level: 17 Points: 1,032, Level: 17 Points: 1,032, Level: 17
Level Up 32% Completed
FF Reputation: 1 Neptune15 Good Standing Member
Thanks.
The strut bearings are new too. I think it's not something with the struts or springs because the noise was there before and after I replaced them.
The brake pads are Motorcraft brake pads, on original rotors, so it's odd that they'd be making the noise. It's not a big deal anyway.
Last I checked for play around the suspension components, everything felt solid.
Could the popping noise be from a bad transmission mount? It kind of does sound like two things banging into each other. It makes the noise when going over bumps and sometimes when I use the clutch pedal. If I'm in neutral and I use the clutch pedal while standing still, there is no noise. It's only when I'm moving and changing gear.
Neptune15 is offline
