Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Tranny fluid changed, now reverse not engaging
Old 12-08-2012, 10:21 AM   #3
elsolo
elsolo's Avatar
Fan#: 96835
What I Drive: 2007 white ZX3
Points 3,182, Level 34
Points: 3,182, Level: 34 Points: 3,182, Level: 34 Points: 3,182, Level: 34
Level Up 88% Completed
Forum Activity 4%
FF Reputation: 18 elsolo Great Standing Member
Definitely take it back to the shop that had the transmission open for service immediately prior to the onset of symptoms.
I doubt it is the pump, that would affect all gears not just Reverse.
The reverse clutch could be not engaging.
when in R, the R clutches and low-1st clutches are engaged.
That is the only time the R clutches are engaged, the low-1st clutches also get engaged if in Manual-1st gear.
So, if the trans seems OK with the gearshift in manual 1st, I would think the reverse clutch is not engaging for some reason.
elsolo is offline
