Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Dome lights
Thread: Dome lights
Old 12-08-2012, 01:45 AM   #62
Sonicbluz
Fan#: 100495
What I Drive: 2012 Sonic Blue Focus s
Points 152, Level 3
Points: 152, Level: 3 Points: 152, Level: 3 Points: 152, Level: 3
Level Up 4% Completed
Level up: 4% Level up: 4% Level up: 4%
FF Reputation: 1 Sonicbluz Good Standing Member
Originally Posted by supernova1 View Post
Here is how it works for me (my car uses two-stage door unlock):
After your car sits closed for several hours
1. Press "Open" on the key fob once - the driver door opens, but dome light is OFF;
2. Press "Close" on the key fob once - the driver door closes;
3. Press "Open" on the key fob once - the driver door opens and the dome light is ON.
I believe that it is a "stealth" feature in case you want to open your car, but do not want to attract attention to it (you figure the case for this), so it has a mode when the dome light is OFF on the first "Open" click.
It also seems to me that this feature has a timer - if you close your car doors and then after several minutes press "Open" again, the dome light will light up. Only after the car sits closed for several hours (can not get the exact time) the dome light is OFF on the first "Open" click.
I can not still figure out the dome light switch with "OFF" sign - to me it just toggles through two states (switch backlight ON/OFF), but does not do anything other than this.
Mine works the same way. At first I had no clue how it worked, Dealer and manual were no help, but through experimenting and reading this forum figured it out. Double click to open also unlocks all doors and turns on all dome lights. Also found if you open the Door less than a second after stealth open, the light comes on.
Sonicbluz is offline
