Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Popping noise
Thread: Popping noise
Old 12-07-2012, 12:28 PM   #3
Fan#: 107031
What I Drive: 2002 Ford Focus ZTS
FF Reputation: 1 mirkrod Good Standing Member
Originally Posted by Geezer View Post
Check your front sway bar end links. They require periodic replacement and cause the noise you describe as they wear out. It's a fairly common problem. They're very easy to replace and reasonably inexpensive (Duralast from Autozone are about 25.00 a pair and decent quality). The other possibilities (also known problem areas) are a broken spring (some early foci had spring quality issues) or a worn out strut mount bearing.
I'll check them out.
mirkrod is offline
