Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Popping noise
Thread: Popping noise
Old 12-07-2012, 11:05 AM   #2
Geezer
Fan#: 1427
Check your front sway bar end links. They require periodic replacement and cause the noise you describe as they wear out. It's a fairly common problem. They're very easy to replace and reasonably inexpensive (Duralast from Autozone are about 25.00 a pair and decent quality). The other possibilities (also known problem areas) are a broken spring (some early foci had spring quality issues) or a worn out strut mount bearing.
Geezer is offline
