Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2001 zx3 wont start
Old 12-07-2012, 12:48 AM   #6
Fan#: 107041
What I Drive: 2001 white ZX3
FF Reputation: 1 H8VTEC Good Standing Member
Originally Posted by iminhell View Post
39 actually, but 7 is definitely under spec.
There's no easy way to do it but I'd almost put a mech. gauge on it and double check that pressure.
Did fuel spray out or did it stream out? Meaning, did it seem like there was good pressure.
Could be the Fuel Rail Pressure Sensor is bad. If it sees low pressure it will send more voltage to the pump and actual pressure might be so high that the car floods almost instantly.
Fuel didnt spray out, but it did push it out....but not 45psi like.i'll check pressure tomorrow with a mechanical gauge. I'll connect it after fuel filter.
H8VTEC is offline
