Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - What Gives!?!?
Thread: What Gives!?!?
Old 12-06-2012, 10:31 PM   #44
PSUrivie
PSUrivie's Avatar
Fan#: 67329
What I Drive: Boostin in the Mid-A
Points 8,736, Level 62
Points: 8,736, Level: 62 Points: 8,736, Level: 62 Points: 8,736, Level: 62
Level Up 96% Completed
FF Reputation: 16 PSUrivie Great Standing Member
Buy-Sell-Trade Rating: (11)
Originally Posted by DarderSauce View Post
Can't quite figure out how others got the e-brake to work cuz mine isn't..... and yes I got the longer SVT e-brake.
But I also haven't looked at it since I did the original swap.
The plastic mounting clips that go into the ebrake mount underneath the car are larger than the holes on the 08+ mount.
You need to grind the outside diameter of the green clips (I used a dremel) until you can get each side to clip into the holes.
FSWerks stg2 w/ water/meth; Cossie intake.
Massive Speed stg 2 cams in the works....
PSUrivie is offline
