Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - clutch? tranny or shfter linkage? need it fixed QUICK!!
Old 12-06-2012, 04:34 PM   #4
#1fordfan
Fan#: 83143
What I Drive: 2005 white se zx4
Points 3,438, Level 36
Points: 3,438, Level: 36 Points: 3,438, Level: 36 Points: 3,438, Level: 36
Level Up 59% Completed
Level up: 59% Level up: 59% Level up: 59%
FF Reputation: 4 #1fordfan Good Standing Member
Originally Posted by warneej View Post
Shift linkage has popped off the transmission. Happened to mine once and I was stuck in 2nd.
the linkage popped off of it's mounting bracket because the white plastic "holding nut"(I am sure that isn't the right term) backed off. I tightened it as tight as I could by hand,didn't want to put pliers on it for fear it would break. Transmission shifts better/more crisp now then it has for a long time!! Obviously this nut has been working itself loose for awhile. Is there anything I can do to stop the nut from backing off again or is it something I just have to remember to check every now and then? Glad it was an easy/free fix,thanks for the quick answers!! I thought it had to be something under the hood,but it was raining and I was pissed and tired this morning,wasn't in the mood to get wet checking it out.
#1fordfan is offline
