Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Need Zetec 3 Lash Caps
Old 12-06-2012, 12:44 AM   #2
amc49
Fan#: 96610
Points 6,252, Level 51
Points: 6,252, Level: 51 Points: 6,252, Level: 51 Points: 6,252, Level: 51
Level Up 51% Completed
Level up: 51% Level up: 51% Level up: 51%
Forum Activity 100%
FF Reputation: 54 amc49 Excellent Standing Member
I'd be leery of what you'd get back in terms of top wear, most would be alright but somebody might foster some junk on you.........if too tight you can get valve shortened slightly for little cost. I've even done it by hand on a cheap bench grinder, but I made a fixture to hold valve square to the wheel.
You may have access to earlier tappets with shim on top that fit around '98 zetecs, they may directly interchange. You can flip shim for new surface too.
I used to swap shims/tappets on bikes, but some of the parts they put out on counter for swap were garbage to me.
amc49 is offline
