Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - ZX3 Black Top
Thread: ZX3 Black Top
Old 12-05-2012, 07:50 PM   #4
sdaddy
sdaddy's Avatar
Fan#: 105173
What I Drive: Green 2002 Birkin w/2L Zetec
Points 139, Level 2
Points: 139, Level: 2 Points: 139, Level: 2 Points: 139, Level: 2
Level Up 78% Completed
FF Reputation: 1 sdaddy Good Standing Member
Originally Posted by 1turbofocus View Post
...sdaddy the only way you will know 100% what the head is gaining would be if you go back with EVERYTHING stock but the port work , stock cams , compression , stock non adj cam gears etc , If your adding compression , cams , adj cam gears thats about 20+ HP gain right there so there would be no way to tell what the head (port work) is doing , interested to see how it does
Tom
Tom, you're right, of course. While my past engine had ITBs, header and adj cam gears, since the C/R and cams are changing at the same time as the head, there's no way to tell the individual impact each has on HP and TQ.
sdaddy is offline
