Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Some one school me!!
Old 12-05-2012, 08:22 PM   #1
need new focus?!
sgtsmasher's Avatar
Fan#: 65000
What I Drive: 01 cd silver 3 door ztec
Points 7,680, Level 58
Points: 7,680, Level: 58 Points: 7,680, Level: 58 Points: 7,680, Level: 58
Level Up 65% Completed
FF Reputation: 2 sgtsmasher Good Standing Member
be easy though, ive been kinda doin my own thing when it comes to subs, amp, hu's and wiring. for example im cheap and hence i have cheap equipment. i'll post the items i have and the specs they come with. what im asking is with what i have, why is it that my buddies 12's can be heard from down the block and he only has 2 1200w american legacy 12's with a pyle 1800w amp in a ported box and a farad 1 rockford cap, and you cant really hear mine coming until half the distance. i want that a system where you can hear me coming from 2 blocks away but not spend a fortune on audio equipment, can anyone help in that department with some audio knowledge please! and i dont want this to turn into a huge argument either.
Pyle PLA2678 2 Channel 4000 Watts Bridgeable Mosfet Amplifier
Maximum Power Output 2 x 2000W 2 Ohm Stable Custom Terminal Block for Speaker Connection S/N Ratio: >90dB
Bridgeable RMS Power @ 4 Ohms: 1x4000W MOSFET Power Supply Thermal Overload Short Circuit Protection
2 Channel Bridgeable MOSFET Amplifier PWM ( Pulse-Width-Modulation ) System Input Impedance: 47K Ohms
Frequency Response 20 Hz-50kHz (3dB) Glass Epoxy PCB Soft Turn On/ Off
Output Power @ 14.4v DC, 50Hz Silver RCA Inputs Advanced Protection Circuitry
Dimensions:10.24"W x 2.21"H x 16.14"L
PYLE PLD15WD 15-Inch 4000 Watt DVC Subwoofer
Custom Titanium Moulded Poly Cone 2.5'' 4 Layer Dual Voice Coil Nominal Impedance: Dual 4 Ohms
Custom Grooved Specially Treated Rubber Surround Moulded Plastic Gasket For Sale:20, Qms:5.03, Qes:0.89, Qts:0.66, Vas (Cu ft)8.689
Diamond Cut Aluminum Die-Cast Basket Spring Loaded Wire Connectors SPL: 92 dB
Dual Stacked Magnet Structure 4000 Watts Peak Power Overall Diameter: 16''
Chrome Mesh Magnet Vent Magnet Weight: 2 x 100 oz. Mounting Depth: 6.40''
(not this exact one but an older model)
AM/FM radio, CD, CD-R/RW, MP3/WMA, SAT/HD-ready, iPod-ready receiver
4 x 52 Watts maximum power with 6-channel pre-amp output
Includes front auxiliary input, remote control
Hatch Nation #72
sgtsmasher is offline
