Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - PTS Remote start from OEM Fob
Old 12-05-2012, 04:52 PM   #44
Michael Jackson
Michael Jackson's Avatar
Fan#: 104370
What I Drive: 2013 Tuxedo Black Hatchback
FF Reputation: 1 Michael Jackson Good Standing Member
Originally Posted by SaToX View Post
Should go into reservation mode with the wire back to stock as the ALCA module picks up the door data via the CAN network.
One other thing to try is use a relay to give a good signal to the clutch wires. I had a jeep that I did the other day and it was hit and miss as to whether it would do the clutch bypass or not. In the end I put a relay to give it a good ground and Voila it worked everytime. Sometimes the 500ma ground that the starters output just aint enough.
Gotcha. That makes a lot of sense. Again, I'll experiment a bit and let you know what happens.
Thanks again!
Sent from my Galaxy Note 2
Michael Jackson is offline
