Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2007 "lifetime" air filter change
Old 12-05-2012, 04:50 PM   #5
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 25,571, Level 96
Points: 25,571, Level: 96 Points: 25,571, Level: 96 Points: 25,571, Level: 96
Level Up 23% Completed
Forum Activity 100%
FF Reputation: 81 felixthecat Excellent Standing Member
Originally Posted by dooor View Post
Getting cold air to the engine while minimizing water intake was what I was thinking about. One persons pita is anothers one time little job with long term benefits.
Why did Ford spec. such a big battery? My 1973 Chev. V8 pickup has a similar battery.
A Steeda sri would work great for that. As far as battery's go= Checkout Tirerack's site= A Braille battery should do the job for you under the hood= 6lbs w/ 527 cranking amps & 210 cca's. Then you wouldn't have to deal w/ running 6lbs of welding cable to your trunk. They have 10 Braille batterys to chose from. I'd rather have more battery then not enough for a DD.
felixthecat is online now
