Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - speedo swap
Thread: speedo swap
Old 12-05-2012, 04:01 PM   #4
crazy_urn
Capt. Urn
crazy_urn's Avatar
Fan#: 1986
What I Drive: 77 F-250, 10 HHR, 08 Outlook
FF Reputation: 5 crazy_urn Good Standing Member
Originally Posted by jlawlax1344 View Post
The speedo swap is a simple plug and play, i did it in about 10 mins myself, same problem. The lens has to be one with a tach as part of the bezel is built into the lens. The mileage will take whatever the new cluster has unless you pay close to 100 to have it saved off the old and onto the new one. IF you need help with it message me on here and i can walk you through it, and i can help you reset the guages (ive only had to reset mine like 8 times!!!)
Before you plan on getting the milage off your old cluster, contact your Ford dealer. When I did this, none of the stealers would re-flash my milage unless I purchased the cluster through them. So I bought a junker a little over my milage, waited impatiently until they were pretty close, then swapped them out. The swap was just as easy as described.
Of course, this was years ago, so it may be different now.
Defending the reputation of the red-headed step-child of the focus world for far too long.
crazy_urn is offline
