Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - A race to the finish!
Old 12-04-2012, 08:18 PM   #1
Rudel
FF's Quadriplegic!
Rudel's Avatar
Fan#: 13465
What I Drive: 2.3 ATX-RSVT
Points 10,628, Level 68
Points: 10,628, Level: 68 Points: 10,628, Level: 68 Points: 10,628, Level: 68
Level Up 45% Completed
FF Reputation: 15 Rudel Great Standing Member
Buy-Sell-Trade Rating: (17)
As most of you know, I'v been having this car worked on for a long time. It wasn't until 2010, when plans changed for the worse...rather maybe the better.
You can read about everything done so far here:
Rude's Ultimate Build....
Other than that I have plenty to do still. In a way, it really is a lot considering the help I need to finish. I say, my car has turned into a community build. If you're in the Tampa area, and have nothing to do, let's get together and get my car done!
  • Driving Controls
  • - Done: Built Zetec Head
  • Sierra RS Hood Vents
  • Hood Vent Drip Pans
  • RS Center Console
  • RS Number Plate stamped with the SVT build #
  • RS Slam Panel Painted & Install
  • - Done: Carbon Fiber Bumper Gills Install
  • Euro Lock Replacement
  • JDM Mirrors
  • Mud Flaps
  • Tail Lights
  • - Done: 5x114.3 Conversion
Currently as she sits:
Engine:
Zetec WRC CGI Block
Focus-Power Zetec 2.3 Stroker Kit -
Focus-Power Custom Forged Pistons
Focus-Power 4340 Billet Steel Rods
Focus-Power 4340 Billet Crank
Focus-Power Billet Main Caps
Focus-Power VTC Delete
Clevit Crank & Rod Bearings
Clevit Thrust Washers
SVT Stock PnP Head
CFM Billet Oil Pump Gears
CFM Billet Tensioner Pulley
J-Fab Crankcase Vent Oil Separator PCV Delete
ARP Main / Head / Manifold Studs
Dominate Engineering Custom Intake Manifold
Focus-Central 70mm Throttle Body
K&N Cone Air Filter
Force Induction:
Garrett GTX-3582R Turbo
Tial .82 SS Exhaust Housing
Tial MVR 44mm Wastegate
Tial Q 50mm BOV
J-Fab Intercooler Support Frame
Top Speed Pro-Race Turbo Manifold
Top Speed Intercooler 3" In / 3.5" Out
Top Speed 3" Hot-side Charge Pipes / 3.5" Cold-side
Top Speed 3.5" Stainless Steel Downpipe
Top Speed 4" Aluminum Exhaust w/ 2 x Vibrant Mufflers
Fuel System:
Siemen Deka 630cc Fuel Injectors
Dominate Engineering -8an Fuel Rail
Aeromotive FPR
Top Speed Dual Fuel Pump Hanger
2 x Walbro 255s
Drivetrain:
Lentech Strip Terminator Automatic Transmission
Ford Racing Torsen T2 Differential
ATX Axles
TCE Wilwood FSL BBK
Goodridge Braided Brake Lines
DGR Coilovers & Camber Plates
Weds Sports SA90s 17x9 +35
Bridgestone RE-01 235/45
Electronic Management:
SCT iTSX
Diablo MAFia
ATX ECU / Transmission Harness
Turbo-smart Boost 2 Controller
AEM Uego Wideband Air/Fuel Ratio Gauge
Defi Fuel/Oil Pressure, EGT, Water/Oil Temp. Gauges
RS Replica Gauge Cluster
Exterior:
RS Body Panels
RS Body Trim
RS Front / Rear Bumpers
RS Front / Rear Fog Lights
RS Upper / Lower Grills
RS Front / Side Blinkers
RS Wheel Arch Liners
RS Bumper Brackets
RS Bumper Side Vents
RS Air Dam
RS Carbon Fiber Fog Light Trim
RS Carbon Fiber Splitter
WRC '99 Viking Wing
European Appearance Package HIDs
Fiberglass Fabricators, Inc. Turbo Fiberglass Hood (Option)
27% Tinted Windows
42 Designs' LEDs
Hoen H7 Foglights
Osram Indicator Bulbs
Modifications:
Battery Relocation
All 3 VF Engineering Engine Mounts
HIDs with both High/Low Beams on when selected.
European Appearance Package Interior
Autopower 4-Point Harness Bar
Ice:
Alpine CDA-9857 Head Unit
Audiophile Premium Sound System
513whp on c16; Tuned by
Part III: Install Handicap Driving Controls
Ma Cah: http://imgur.com/a/TuyYL
Rudel is offline
