Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - battery light
Thread: battery light
Old 12-04-2012, 12:51 PM   #13
Eiron
Fan#: 77999
What I Drive: 2002 Red Wagon
Points 452, Level 9
Points: 452, Level: 9 Points: 452, Level: 9 Points: 452, Level: 9
Level Up 4% Completed
Level up: 4% Level up: 4% Level up: 4%
FF Reputation: 3 Eiron Good Standing Member
Make sure your battery cables are all solid/intact, especially at the battery clamps. If you have broken wire strands at the clamps then that could be shortening the life of both the alternator & the battery. This happened on our '02 Focus wagon (went thru 2 batteries & 2 alts) & was only fixed after rebuilding the positive cable's battery clamp.
The alt-to-starter cable could also be a candidate for problems, but that cable doesn't usually see the amount of disconnecting that the battery cables do, so it's less likely to be a problem.
"Help, Mr. Wiza-a-ard!!"
Eiron is offline
