Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Oil, gas in intake manifold????
Old 12-04-2012, 12:01 PM   #3
silvrbuletZX3
silvrbuletZX3's Avatar
Fan#: 42750
What I Drive: 2003 white ZX5 / 2013 ST
Points 1,565, Level 22
Points: 1,565, Level: 22 Points: 1,565, Level: 22 Points: 1,565, Level: 22
Level Up 65% Completed
FF Reputation: 1 silvrbuletZX3 Good Standing Member
Originally Posted by Andrews-bad-SE View Post
You have any pics of it? From what I understand, the fuel injectors throw fuel in right before the intake valves, right inside the intake manifold. Over time the intake manifold will get gunky and varnishy from fuel and stuff. Try running some seafoam through it, and really clean it carefully and well. It's very common, and happens to all cars. Probably nothing bad :)
I don't think a bad piston ring would cause your intake to gum up, because if your intake valves are still good, they wouldn't let anything through on the compression or exhaust stroke. If your problem persists, I'd look at the valves, make sure they're seating nicely like they should be. Has your car ever been overheated, or anything like that?
Your stalling problem could be tied to a dirty IAC (idle air control valve). If your intake is dirty, chances are that thing is just plain grody too. There are various how-to's on this forum, with pictures and great advice on how to clean that bad boy.
Check for vacuum leaks. I'm checking for some on mine, too lol.
Check/clean your Mass Airflow Sensor (MAF) and make sure it's in the right way.
Check your air filter, and all your PCV's and PCV hoses.
Any check engine lights?
Thanks ill look into that.
The fuel oil mixture was nice and liquid not gummy or anything but it is dirty I sprayed intake cleaner in it and the car still acts up but not as much.
The CEL is on I don't remember the #s but it said it is running lean and or not enough air or something like that
2013 Tangerine Scream ST
Hers, 2003 White ZX5
Sold 2004 Silver ZX3
Sold, 2003 Red SVTF ZX5
silvrbuletZX3 is offline
