Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2012 focus
Thread: 2012 focus
Old 12-04-2012, 11:42 AM   #28
mr_cassandra
Fan#: 95399
What I Drive: VW GTI, Mazda-3 after 2012-Focus
Points 579, Level 11
Points: 579, Level: 11 Points: 579, Level: 11 Points: 579, Level: 11
Level Up 58% Completed
Level up: 58% Level up: 58% Level up: 58%
Forum Activity 10%
Activity: 10% Activity: 10% Activity: 10%
FF Reputation: 2 mr_cassandra Good Standing Member
Originally Posted by r1ch999999 View Post
I'm wishing I bought the manual, 700 miles on my Focus and I think I'm having the same issue.
have you consulted your dealer? there are two technical service bulletins and one recall that I know of that apply to hesitation, stutter, etc on the automatic.
be aware that "some" hesitation-stutter IS normal at very low speed shifts BUT this is NOT a one size fits all explanation.
Take your time to read all the posts here because you will see that the transmission problems range from very mild-normal for this type transmission to others so bad the dealer needed to remove the transmission and replace seals and/or throwout bearings.
If you take your time and read all the posts, you may end up knowing more than the dealer and I have found if you are pro-active and know the subject well, Ford can and does want you to be happy.
All my transmission problems completely disappeared when the cold new england weather hit, and I had 12,000 miles at the point. How could these problems disappear if they are normal?
When this transmission is running properly, you can not get a sportier, economical, more fun car unless you want to spend $10,000 more.
mr_cassandra is offline
