Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Winter Fuel Econcomy
Old 12-03-2012, 10:17 PM   #12
jsr72
jsr72's Avatar
Fan#: 97393
What I Drive: MK III
Points 186, Level 3
Points: 186, Level: 3 Points: 186, Level: 3 Points: 186, Level: 3
Level Up 72% Completed
FF Reputation: 6 jsr72 Good Standing Member
Originally Posted by GoShockers View Post
Also, how much of an impact on fuel mileage does cold air cause? Let's take away the fuel aspect and perhaps even the warm-up period. Does the colder, denser, "heavier" air cause enough problems aerodynamically to make a difference?
To produce an identical level of aerodynamic form drag, if the air density is increased then the velocity must correspondingly decrease.
In highly idealized situation if the air pressure happens to be the same at two different temperatures, then the new velocity is simply the original velocity times the square root of the new temperature divided by the square root of the original temperature. (Use absolute temperatures in the calculation)
For instance, if a vehicle is traveling 70 mph at 70F, then it experiences the same amount of form drag at 67.3 mph at 30F.
jsr72 is offline
