Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - MFT 3.5.1 bugs
Thread: MFT 3.5.1 bugs
Old 12-03-2012, 11:33 AM   #58
I Bleed Ford Blue
I Bleed Ford Blue's Avatar
Fan#: 94113
What I Drive: 2013 F150 FX4
Points 2,541, Level 30
Points: 2,541, Level: 30 Points: 2,541, Level: 30 Points: 2,541, Level: 30
Level Up 61% Completed
FF Reputation: 8 I Bleed Ford Blue Good Standing Member
Originally Posted by peridigm View Post
If they do intend for it to default to USB it probably has more to do with the update procedure and MFT checking for existence of USB first. Similar to the boot order of a PC.
Yeah, I thought about that. But on a pc, you can select boot device. They should give you the option so you can leave your usb stick plugged in or ipod or whatever w/o it playing on startup. It would very easy to make the last selected device (AM, FM, disc, sirrus or usb the default device on startup for the entertainment portion and still have the mft itself look for a usb device for updates on startup. All they need to do is include an .ini or .exe file on the usb stick with the update and have the mft look for it on startup, if it is not found then boot into last selection, that simple.
13 Blue Flame F150 FX4 402A on 20's loaded
13 Frosted Glass Escape Ti 401A loaded
13 Performance Blue SE 201A
14 Dark Side Fusion SE 200A
L-CCC #18/HOIA #37
I Bleed Ford Blue is offline
