Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - MFT 3.5.1 bugs
Thread: MFT 3.5.1 bugs
Old 12-03-2012, 10:48 AM   #56
I Bleed Ford Blue
I Bleed Ford Blue's Avatar
Fan#: 94113
What I Drive: 2013 F150 FX4
Points 2,541, Level 30
Points: 2,541, Level: 30 Points: 2,541, Level: 30 Points: 2,541, Level: 30
Level Up 61% Completed
FF Reputation: 8 I Bleed Ford Blue Good Standing Member
Originally Posted by Aychdot View Post
Mine works pretty well except when I start the car. MFT wants to start at the first track on my usb no matter what I was previously listening to.
Mine does this also, but randomly. I talked to the salesman who is the sync guru at the dealer and he said that entertainment portion of MFT is supposed to default to the usb on startup. I asked if that was true then why is it random? His response was the usb stick might be loose or something in the console could be bumping the stick and dislodging it causing it to not be recognized.
On the bright side if this happening mostly on 3.5.1 then that means ford is getting closer to getting the MFT to operate as intended, because mine never did this until 351.
On a side note if it is true that mft defaults to the usb on startup, then I would request that on the next update, that this be changed to default to the last selection. I mean who wants to (or can remember) to unplug the usb stick every day then plug it back in when you want to listen to it.
13 Blue Flame F150 FX4 402A on 20's loaded
13 Frosted Glass Escape Ti 401A loaded
13 Performance Blue SE 201A
14 Dark Side Fusion SE 200A
L-CCC #18/HOIA #37
I Bleed Ford Blue is offline
