Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Ford recall: 1.6L Ecoboost catching fire
Old 12-03-2012, 08:54 AM   #15
2012silversel
2012silversel's Avatar
Fan#: 83969
What I Drive: 2014 C-Max Energi, Sterling Gray
Points 2,058, Level 27
Points: 2,058, Level: 27 Points: 2,058, Level: 27 Points: 2,058, Level: 27
Level Up 39% Completed
FF Reputation: 1 2012silversel Good Standing Member
Apparently it could be a couple of things. Some frost plugs may be improperly installed causing them to pop out, the coolant leaks on to the exhaust, the water evaporates and the glyco starts the fire. The other thing I read is there is a maze of coolant lines behind the engine, any leaks will result in the same as above.
2012silversel is offline
