Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Any way to connect sub to stock radio??
Old 12-03-2012, 03:15 AM   #2
gurkpimpin
gurkpimpin's Avatar
Fan#: 63495
What I Drive: 2001 Tornado Red Focus Sedan
Points 373, Level 7
Points: 373, Level: 7 Points: 373, Level: 7 Points: 373, Level: 7
Level Up 46% Completed
FF Reputation: 2 gurkpimpin Good Standing Member
You will have run the blue remote wire to the fuse box and tie it in to one of the fuses that turn on with the car that way the amp powers on and off with the car and doesn't drain your battery..the RCA cables will hook onto the the amp normal but the other end will have to be cut off and spliced into the one of the back speakers I would go with the one closes to the amp..so negative on negative and positive on positive..hope that helps you should know where the rest goes and make sure to wire the sub to the mono channel + to the left + and the - to the right - and always match the wires up don't forget about the ground to the chassis and the battery cable to the + battery post.
Sent from my SPH-D700 using FF Mobile
My Focus Is Just A Focus For Now But Who Knows Wait Awaits Diablo. "If guns kill people then,pencils misspell words, cars make people drive drunk and...spoons made Rosie O' Donnell fat"
gurkpimpin is offline
