Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Duratec 2.0L owners.. do you experience long cranking/need for multiple start attempts?
Old 12-02-2012, 06:28 PM   #6
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 32,635, Level 100
Points: 32,635, Level: 100 Points: 32,635, Level: 100 Points: 32,635, Level: 100
Forum Activity 41%
Activity: 41% Activity: 41% Activity: 41%
That sounds like the same issue. Another way I'd get around it was by bumping the key, then 1, 2, then starting. That gives you 2 fuel squirts and enough time for the first one to form vapor. That might not be a good method when it's cold. EFI engines can flood too, but the way to clear a flooded engine is similar. It's also called Emergency start mode: key off, press and hold accelerator to the floor, then crank the engine. No fuel will be sprayed, if there is fuel in there already when it's sufficiently mixed it will start. Just let off the gas when it does, and it will idle.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is online now
