Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Ford Focus center bore size on 2013 focus se hatch
Old 12-02-2012, 10:00 AM   #13
sailor
Old Phart
sailor's Avatar
Fan#: 57268
Points 31,317, Level 100
Points: 31,317, Level: 100 Points: 31,317, Level: 100 Points: 31,317, Level: 100
Forum Activity 100%
FF Reputation: 133 sailor Excellent Standing Member sailor Excellent Standing Member
Umm....
48-25=23, 23 is less than 55 by 33mm, so with 48 mm offset wheels & a 25mm spacer your wheels would stick out 33mm more than the stock ones.
Not understanding your 1.25" adapter post, Zillon was guessing a typical 25mm thickness for adapters - do you know the actual thickness of the ones you want to use?
Hmmm - if they ARE 1.25" thick, that would be roughly 29mm (not near the ruler I like to use for a quick check of rough estimate), so about 36mm extra stick out....
sailor is offline
