Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Ford Focus center bore size on 2013 focus se hatch
Old 12-02-2012, 08:39 AM   #11
Zillon
Zillon's Avatar
Fan#: 17393
What I Drive: '13 JCW GP
Points 2,504, Level 30
Points: 2,504, Level: 30 Points: 2,504, Level: 30 Points: 2,504, Level: 30
Level Up 36% Completed
FF Reputation: 27 Zillon Great Standing Member
Buy-Sell-Trade Rating: (3)
Originally Posted by FocusHatch13 View Post
Plus my wheel has a 35mm offset... I'm not going to rub right?? 17x8 with tire 225x45x17
You've got the wrong idea about how offset works, unfortunately.
Offset is the distance from the centerline of the wheel to the flat area (plane) of the mounting surface. Thus, +/- 0 offset is a wheel whose mounting surface is at the center of the wheel. So, the higher the number, the more the wheel sits in towards the center of the vehicle.
At 55mm, the factory Ti wheels are considered to have a fairly high offset. Your wheels, at 35mm, definitely won't fit. With the spacers, the offset will drop to 10mm, since it brings the mounting surface closer to the center of the wheel. You're looking at a setup that absolutely won't fit on the Focus.
Here's a good calculator that will explain things in a more concise fashion: http://marksink.com/tire_wheel_offset/offset.html
Joined the dark side.
Zillon is offline
