Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Header install questions
Old 12-01-2012, 02:54 PM   #4
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 25,214, Level 95
Points: 25,214, Level: 95 Points: 25,214, Level: 95 Points: 25,214, Level: 95
Level Up 87% Completed
Level up: 87% Level up: 87% Level up: 87%
Forum Activity 100%
FF Reputation: 81 felixthecat Excellent Standing Member
I found I had to oblong the bolt holes on the bracket that supports the manifold. I oblonged the side that bolts to the header. The one that bolts to the block & manifold. I also removed the fuel evact canister on the firewall. I reused the oem gasket also. Better than the ford replacement one. I tighten them in sequance to 35lbs in 3 steps. Top to bottom then top, ect.
felixthecat is offline
