Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2010 focus air in lines after brake job
Old 11-30-2012, 06:52 PM   #19
GO.army.1969
GO.army.1969's Avatar
Fan#: 69605
What I Drive: 2008 Vapor Silver Coupe 5 speed
Points 2,851, Level 32
Points: 2,851, Level: 32 Points: 2,851, Level: 32 Points: 2,851, Level: 32
Level Up 68% Completed
FF Reputation: 15 GO.army.1969 Great Standing Member
Ok this is not cool you realy need another helper or something. pump the brake pedal SLOW 5 to 8 times and hold do not ram the brake padal to the floor while pumping or bleedeng. loosen the bleeder valve very slowly. Close the valve before the pedal hits the floor do this 5 times before you move to the next wheel. It also helps if you have some clear tubing so you can see if there is air coming out while you are bleeding.
PS: make sure the master cylinder is full to start. bleed two times check and fill master cylinder repeat every two bleed's and make sure to put the brake cap back on each time. like said before start with the rear pass side then rear driver side then move to the front pass side last do the driver side rember pump slow beed slow 5 times each wheel. if this does not work tow it to the shop and pay someone to do if for you. sorry if this sound like im being mean but wow it is realy easy to do. And NO dont waste you time with doing the gravity bleed. Sorry fast*st
NW Posse#10 Team Duratec#69
F2 Header, Steath Exhaust, CAI, AR103, Tuned by Randy Fswerks, DGR Coil Overs
DOMINANT front and rear LCA DOMINANT endlinks Massive toe and camber arms
GO.army.1969 is offline
