Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2008-2011 Projector Retrofit Guide: Morimoto Mini H1
Old 11-29-2012, 03:04 PM   #3
A7xschecter6661
A7xschecter6661's Avatar
Fan#: 98263
What I Drive: 2011 Focus SEL
FF Reputation: 2 A7xschecter6661 Good Standing Member
When I installl them I will include that. I will tell you know but it might be hard to understand.
Passenger side is grounded with a purple wired engine? ground that sits right on the top of the frame. Look at the top of your engine and then look left and down and it's right there. (the ballast is mounted on the same frame area just closer to the headlight.
Driver side ground wire is attached to the speed bolt where the fender I think attached to the frame. Ballast is mounted right on top of the frame where there is a riveted on metal tag.
A7xschecter6661 is offline
