Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - General 2012 Focus Information and Specs(Work in progress)
Old 11-29-2012, 02:36 PM   #21
oritpro's Avatar
Fan#: 96148
What I Drive: 2012 Subaru Impreza Sport Limited
Points 749, Level 14
Points: 749, Level: 14 Points: 749, Level: 14 Points: 749, Level: 14
Level Up 49% Completed
FF Reputation: 2 oritpro Good Standing Member
Originally Posted by 2012sel View Post
I'm missing a screw and a plastic push pin used to fasten the front aero shield (the plastic part under the car in front of the felt shield you remove to do an oil change). I suspect that I'll eventually strip the little red frame inserts that these screws go into as well. If anyone out there knows what I'm talking about and has part numbers please post. Otherwise, when I get the replacements I'll send pictures and part numbers. Note there are two lengths of screws used in both aero panels. The longer ones go into a metal clip and the shorter ones go into square red inserts on the frame.
Not sure if this will help but I was at Lowes a couple weeks ago and they had plastic automotive clips, push pins, and fasteners.
oritpro is offline
