Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Lowering
Thread: Lowering
Old 11-29-2012, 09:55 AM   #4
Mile30
Mile30's Avatar
Fan#: 74686
What I Drive: '03 ZX3
Points 9,559, Level 65
Points: 9,559, Level: 65 Points: 9,559, Level: 65 Points: 9,559, Level: 65
Level Up 70% Completed
Forum Activity 5%
FF Reputation: 7 Mile30 Good Standing Member
Buy-Sell-Trade Rating: (11)
You could go with a coil-over setup. Most people that are that low started with a standard coil-over setup, then they cut bumpstops and the helper spring (or remove it all together). You're gonna re-learn driving your car anyway, as the connection to the road feels different. TA Technix is the cheapest coil over setup you'll find for the mkI. It used to be Raceland, but those sold out quickly and Technix took it's place. That setup will allow you to run anywhere from stock height down to 4" lower than stock without cutting or modification of the pieces! You can go an inch or two lower than that by cutting those aforementioned parts; but leaving them in-place makes for a safer install and gives you slightly better regular driving behavior.
"I'm gonna sing the doom song..."
Mile30 is offline
