Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Ford Focus shaking up and down at speeds 30km/h-50km/h (I'm canadian lol)
Old 11-28-2012, 08:54 PM   #6
gello88's Avatar
Fan#: 102250
What I Drive: 2000 Black ZX3
FF Reputation: 1 gello88 Good Standing Member
Originally Posted by thenorm View Post
offset shouldnt matter.
the wheels are tight against the hub? and the lugnuts arent bottomed out? (open or closed lugs?)
I'm betting on wheel balance.
yo can easily check the out lip of your wheels, there should be a crimp on weight on each wheel.
The lugnuts are open (thats when the lugnuts are open on both ends right?) The wheels are tight against the hub, I tightened the lugnuts to spec (95 lbs. ft.).
The steel wheels that I'm using are aftermarket but I told the store that it's for my Ford Focus and they gave me the wheels. They lugnut holes fit perfectly on the hub. Not sure if the wheels are hub-centric though. How do you even know if it's "hub-centric" ?
I also did notice that one of the steel wheels do not have any wheel weights. The other three steel wheels have wheel weights.
gello88 is offline
