Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Installation of rear springs.
Old 11-28-2012, 03:54 PM   #2
thenorm
thenorm's Avatar
Fan#: 14947
What I Drive: '04 ZX3, '14 Mustang GT
Points 7,541, Level 57
Points: 7,541, Level: 57 Points: 7,541, Level: 57 Points: 7,541, Level: 57
Level Up 96% Completed
Forum Activity 12%
Activity: 12% Activity: 12% Activity: 12%
FF Reputation: 43 thenorm Great Standing Member
Buy-Sell-Trade Rating: (5)
I did this a few weeks ago, but with one minor adjustment.
I was going from lowering spring back to stock, so the short lowering springs came out easy.
-to get the tall stock spring in, i used my strut spring compressors that i already had, then I used 2 rachet straps (1000lb rating each) to hold the spring compressed while i removed the spring compressor.
-then pry down the lower control arm and put hte spring in.
-Using a floor jack to raise the control arm and compress the spring, i could then safely remove the rachet straps.
NOTE: i do not recomend using the rachet straps to physically do the compressing. I was only using it to hold the springs. And please ensure if you try this you use high capacity straps. (i figured each spring load rating is about 750lbs, to I tripled it to 2000lbs.)
May 2014 ROTM, June 2015 ROTM
for rally-x: '04 Liquid Grey ZX3
Build Thread:
Sold: '02 Infrared SVT
thenorm is offline
