Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2010 focus air in lines after brake job
Old 11-28-2012, 12:14 PM   #13
GO.army.1969
GO.army.1969's Avatar
Fan#: 69605
What I Drive: 2008 Vapor Silver Coupe 5 speed
Points 2,851, Level 32
Points: 2,851, Level: 32 Points: 2,851, Level: 32 Points: 2,851, Level: 32
Level Up 68% Completed
FF Reputation: 15 GO.army.1969 Great Standing Member
Originally Posted by Geezer View Post
I never liked the hold part (bottoming the pedal) and then shutting the valve in a two person bleed job. I always shut the bleeder valve "before" the pedal reaches bottom (and while fluid is still coming out). This eliminates any possibility of air being allowed back in the system. I also bleed each corner one more time after air bubbles have totally disappeared.
I feel the same way about brake bleeding. I thought it was just me being anal about bleeding my brakes. Plus I make sure to use only a new bottle of brake fluid so I either get two small bottles or a large bottle of brake. I do this every two years or when I put new pads on.
NW Posse#10 Team Duratec#69
F2 Header, Steath Exhaust, CAI, AR103, Tuned by Randy Fswerks, DGR Coil Overs
DOMINANT front and rear LCA DOMINANT endlinks Massive toe and camber arms
GO.army.1969 is offline
