Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Help!! 2013 focus. Need your input.
Old 11-28-2012, 10:55 AM   #30
Just Tom
Just Tom's Avatar
Fan#: 106663
What I Drive: 2013 Focus Ti (5 Dr.)
Points 2,482, Level 30
Points: 2,482, Level: 30 Points: 2,482, Level: 30 Points: 2,482, Level: 30
Level Up 22% Completed
FF Reputation: 3 Just Tom Good Standing Member
Selectshift is the S gate on the gear shift lever which also allows for manual shifting through the gears without the use of a clutch pedal with the click of the switch on the gear lever. If putting it into S without touching the switch the car remains in sport shift automatic mode which uses gears 1-5, and more aggressively downshifts on braking to bring the engine speed up to keep the car in the powerband.
Powershift is Ford's trademarked name for the dual clutch automated manual transmission (DCT).
The Titanium if it is an auto will have the PowerShift DPS6 with the Selectshift feature.
The base S/SE with the Powershift transmission only have a L range instead of a sport mode as well as a hill grade assist switch that locks the car out of 6th gear instead of the manual shift switch.
Thanks for that explaination, that makes sense to me now. This forum and folks like yourself sure are a great resource. Thanks for taking the time to respond.
Just Tom is offline
